Power Mac G4 Cube Modem Replacement
  1. Power Mac G4 Cube Modem Replacement, Outer Case: step 1, image 1 of 3 Power Mac G4 Cube Modem Replacement, Outer Case: step 1, image 2 of 3 Power Mac G4 Cube Modem Replacement, Outer Case: step 1, image 3 of 3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Modem Replacement: step 2, image 1 of 2 Power Mac G4 Cube Modem Replacement: step 2, image 2 of 2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Modem Replacement: step 3, image 1 of 1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Modem Replacement: step 4, image 1 of 1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Modem Replacement, Video Card: step 5, image 1 of 1
    • Remove the screws on the back of the VGA port.
  6. Power Mac G4 Cube Modem Replacement: step 6, image 1 of 1
    • Remove the screw attaching the video card to the logic board.
  7. Power Mac G4 Cube Modem Replacement: step 7, image 1 of 2 Power Mac G4 Cube Modem Replacement: step 7, image 2 of 2
    • Remove power cord from the video card.
  8. Power Mac G4 Cube Modem Replacement: step 8, image 1 of 1
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  9. Power Mac G4 Cube Modem Replacement: step 9, image 1 of 1
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  10. Power Mac G4 Cube Modem Replacement: step 10, image 1 of 2 Power Mac G4 Cube Modem Replacement: step 10, image 2 of 2
    • Separate the video card from the adapter.
  11. Power Mac G4 Cube Modem Replacement, Modem: step 11, image 1 of 1
    • Remove the two screws from the modem.
  12. Power Mac G4 Cube Modem Replacement: step 12, image 1 of 1
    • Lift modem from the Logic Board.
    • The modem should come out easily.
3 other people completed this guide.
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 4,448
