Power Mac G4 M5183 Hard Drive Replacement
  1. Power Mac G4 M5183 Hard Drive Replacement, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Power Mac G4 M5183 Hard Drive Replacement, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Hard Drive Replacement, Hard Drive: step 2, image 1 of 2 Power Mac G4 M5183 Hard Drive Replacement, Hard Drive: step 2, image 2 of 2
    • Remove the ribbon cable and power cable from the Hard Drive.
  3. Power Mac G4 M5183 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the screw which holds the Hard Drive tray in place.
  4. Power Mac G4 M5183 Hard Drive Replacement: step 4, image 1 of 1
    • Slide the Hard Drive tray out of the computer.
  5. Power Mac G4 M5183 Hard Drive Replacement: step 5, image 1 of 1
    • To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
Finish Line
36 other people completed this guide.
Justin Petrilli
3,114 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 73
All Time: 26,836
