Power Macintosh G3 Blue and White Graphics Card Replacement
[deleted]
[deleted] and one other contributor
Last updated on December 17, 2024
5 - 10 minutes
Easy
Community-Contributed Guide
iFixit earns commission when you buy through these links.
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: step 1, image 1 of 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: step 2, image 1 of 2 Power Macintosh G3 Blue and White Graphics Card Replacement: step 2, image 2 of 2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: step 3, image 1 of 1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
3 other people completed this guide.
[deleted]
27,051 Reputation
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 44
All Time: 1,805
