Power Macintosh G3 Blue and White Modem Replacement
  1. Power Macintosh G3 Blue and White Modem Replacement, Before opening up your Power Mac...: step 1, image 1 of 1
    • Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
  2. Power Macintosh G3 Blue and White Modem Replacement: step 2, image 1 of 1
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  3. Power Macintosh G3 Blue and White Modem Replacement: step 3, image 1 of 1
    • Remove the single Phillips #1 screw circled in the picture.
    • I apologize for the lack of picture quality. The only camera and lighting I had were my iPhone X´s camera and a table lamp. Lol!
  4. Power Macintosh G3 Blue and White Modem Replacement: step 4, image 1 of 1
    • Disconnect the modem’s flex cable from the connector on the logic board.
    • Lift the modem assembly out of it´s place on the logic board.
2 other people completed this guide.
[deleted]
26,583 Reputation
21 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 19
All Time: 673
