Power Supply Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Power Supply Removal, Uncover the back panel screws: step 1, image 1 of 2 Power Supply Removal, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. Power Supply Removal: step 2, image 1 of 3 Power Supply Removal: step 2, image 2 of 3 Power Supply Removal: step 2, image 3 of 3
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. Power Supply Removal: step 3, image 1 of 3 Power Supply Removal: step 3, image 2 of 3 Power Supply Removal: step 3, image 3 of 3
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. Power Supply Removal: step 4, image 1 of 3 Power Supply Removal: step 4, image 2 of 3 Power Supply Removal: step 4, image 3 of 3
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. Power Supply Removal, Remove the back panel screws: step 5, image 1 of 2 Power Supply Removal, Remove the back panel screws: step 5, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. Power Supply Removal, Unclip the back panel: step 6, image 1 of 3 Power Supply Removal, Unclip the back panel: step 6, image 2 of 3 Power Supply Removal, Unclip the back panel: step 6, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. Power Supply Removal: step 7, image 1 of 3 Power Supply Removal: step 7, image 2 of 3 Power Supply Removal: step 7, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. Power Supply Removal, Remove the back panel: step 8, image 1 of 3 Power Supply Removal, Remove the back panel: step 8, image 2 of 3 Power Supply Removal, Remove the back panel: step 8, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. Power Supply Removal: step 9, image 1 of 3 Power Supply Removal: step 9, image 2 of 3 Power Supply Removal: step 9, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. Power Supply Removal, Remove the fan screws: step 10, image 1 of 2 Power Supply Removal, Remove the fan screws: step 10, image 2 of 2
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.3 mm‑long pancake screw
    • Two 9 mm‑long screws
  11. Power Supply Removal, Disconnect the fan cable: step 11, image 1 of 3 Power Supply Removal, Disconnect the fan cable: step 11, image 2 of 3 Power Supply Removal, Disconnect the fan cable: step 11, image 3 of 3
    • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
    • Grip your tweezers close the connector to get a better grip.
    • Pull the connector straight out of the socket to disconnect it.
    • If you're having trouble, gently rock the connector side to side to loosen it.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  12. Power Supply Removal, Remove the fan: step 12, image 1 of 3 Power Supply Removal, Remove the fan: step 12, image 2 of 3 Power Supply Removal, Remove the fan: step 12, image 3 of 3
    Dust Blower
    $18.99
    Buy
    • Slide the fan out of its slot to remove it.
    • During reassembly:
    • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • Note that the fan can only be installed one way—make sure Master Chief is facing you.
  13. Power Supply Removal, Unlatch the base: step 13, image 1 of 3 Power Supply Removal, Unlatch the base: step 13, image 2 of 3 Power Supply Removal, Unlatch the base: step 13, image 3 of 3
    • Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
    • Keep the locking tab held open for the next step.
  14. Power Supply Removal, Twist and remove the base: step 14, image 1 of 3 Power Supply Removal, Twist and remove the base: step 14, image 2 of 3 Power Supply Removal, Twist and remove the base: step 14, image 3 of 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
  15. Power Supply Removal, Disconnect the USB port cable: step 15, image 1 of 3 Power Supply Removal, Disconnect the USB port cable: step 15, image 2 of 3 Power Supply Removal, Disconnect the USB port cable: step 15, image 3 of 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  16. Power Supply Removal, Heat the USB port cable: step 16, image 1 of 3 Power Supply Removal, Heat the USB port cable: step 16, image 2 of 3 Power Supply Removal, Heat the USB port cable: step 16, image 3 of 3
    • The USB port cable is secured to the chassis with two pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the USB port cable.
  17. Power Supply Removal, Detach the USB port cable: step 17, image 1 of 3 Power Supply Removal, Detach the USB port cable: step 17, image 2 of 3 Power Supply Removal, Detach the USB port cable: step 17, image 3 of 3
    Tesa 61395 Tape
    $2.99
    Buy
    • Slide an opening pick under the USB port cable to separate the adhesive securing it.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  18. Power Supply Removal: step 18, image 1 of 3 Power Supply Removal: step 18, image 2 of 3 Power Supply Removal: step 18, image 3 of 3
    • Use a pair of tweezers to gently pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • Move the USB port cable out of the way of the chassis.
  19. Power Supply Removal, Disconnect the power button cable: step 19, image 1 of 3 Power Supply Removal, Disconnect the power button cable: step 19, image 2 of 3 Power Supply Removal, Disconnect the power button cable: step 19, image 3 of 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Power Supply Removal, Remove the chassis screws: step 20, image 1 of 2 Power Supply Removal, Remove the chassis screws: step 20, image 2 of 2
    • Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
  21. Power Supply Removal, Remove the chassis: step 21, image 1 of 3 Power Supply Removal, Remove the chassis: step 21, image 2 of 3 Power Supply Removal, Remove the chassis: step 21, image 3 of 3
    • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Use two hands to lift out the chassis to remove it from the shell.
    • Make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
    • Use the alignment pegs and cutouts to properly orient the chassis in the shell:
    • Two pegs on the chassis with cutouts on the bottom of the shell.
    • Three pegs in the shell with cutouts on the chassis.
  22. Power Supply Removal: step 22, image 1 of 2 Power Supply Removal: step 22, image 2 of 2
    Dust Blower
    $5.99
    Buy
    • Gently place the chassis heatsink-side down on a clean work surface.
    • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
  23. Power Supply Removal, Remove the antenna board screws: step 23, image 1 of 2 Power Supply Removal, Remove the antenna board screws: step 23, image 2 of 2
    • Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
  24. Power Supply Removal, Remove the accessory antenna board: step 24, image 1 of 3 Power Supply Removal, Remove the accessory antenna board: step 24, image 2 of 3 Power Supply Removal, Remove the accessory antenna board: step 24, image 3 of 3
    • Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  25. Power Supply Removal, Remove the power cable port: step 25, image 1 of 2 Power Supply Removal, Remove the power cable port: step 25, image 2 of 2
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm‑long screws
    • One 35 mm‑long screw
  26. Power Supply Removal: step 26, image 1 of 2 Power Supply Removal: step 26, image 2 of 2
    • Lift the power connector out of its recess in the chassis.
  27. Power Supply Removal, De-route the power cables: step 27, image 1 of 2 Power Supply Removal, De-route the power cables: step 27, image 2 of 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Power Supply Removal: step 28, image 1 of 2 Power Supply Removal: step 28, image 2 of 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Power Supply Removal, Remove the board shield: step 29, image 1 of 2 Power Supply Removal, Remove the board shield: step 29, image 2 of 2
    • Use a T8 Torx driver to remove the ten screws securing the board shield:
    • Seven 8.7 mm‑long screws
    • Two 35 mm‑long screws
    • These screws are very tight and may take significant force to loosen.
    • One 13 mm‑long screw
  30. Power Supply Removal: step 30, image 1 of 3 Power Supply Removal: step 30, image 2 of 3 Power Supply Removal: step 30, image 3 of 3
    • Hold the power supply cable out of the way and lift the board shield straight up to remove it.
  31. Power Supply Removal, Disconnect the power supply cables: step 31, image 1 of 3 Power Supply Removal, Disconnect the power supply cables: step 31, image 2 of 3 Power Supply Removal, Disconnect the power supply cables: step 31, image 3 of 3
    • Open the lid on the power supply's plastic cable guide.
  32. Power Supply Removal: step 32, image 1 of 3 Power Supply Removal: step 32, image 2 of 3 Power Supply Removal: step 32, image 3 of 3
    • Use your fingers to pinch the power supply's two‑pin power connector, so the locking tab opens outward.
    • With the locking tab open, lift the connector straight up and out of its socket.
  33. Power Supply Removal: step 33, image 1 of 3 Power Supply Removal: step 33, image 2 of 3 Power Supply Removal: step 33, image 3 of 3
    • Repeat the previous step to disconnect the power supply's 10‑pin connector.
  34. Power Supply Removal, Unlatch the chassis strap: step 34, image 1 of 3 Power Supply Removal, Unlatch the chassis strap: step 34, image 2 of 3 Power Supply Removal, Unlatch the chassis strap: step 34, image 3 of 3
    • Pull the end of the rubber strap down and away from the chassis to unlatch it.
  35. Power Supply Removal: step 35, image 1 of 3 Power Supply Removal: step 35, image 2 of 3 Power Supply Removal: step 35, image 3 of 3
    • Pull the chassis strap off its three alignment posts and unlatch it from the sides of the power supply.
    • You can leave the strap under the chassis or remove it.
    • During reassembly, make sure the nubs in the middle of the strap go unto their cutouts on the heat sink fins.
  36. Power Supply Removal, Remove the power supply screws: step 36, image 1 of 2 Power Supply Removal, Remove the power supply screws: step 36, image 2 of 2
    • Use a T8 Torx driver to remove the four screws securing the corners of the power supply:
    • Three 35 mm‑long silver screws
    • One 8.7 mm‑long black screw
  37. Power Supply Removal, Remove the power supply: step 37, image 1 of 2 Power Supply Removal, Remove the power supply: step 37, image 2 of 2
    • Lift the power supply straight up and remove it.
Finish Line
Spencer Day
155,267 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 56
