PowerA Spectra Contoller D-Pad Replacement
  1. PowerA Spectra Contoller D-Pad Replacement, Rear Case: step 1, image 1 of 1
    • Flip the controller over so the backplate is facing up.
  2. PowerA Spectra Contoller D-Pad Replacement: step 2, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
  3. PowerA Spectra Contoller D-Pad Replacement: step 3, image 1 of 1
    • Hold the front case in one hand and pull the rear case off.
  4. PowerA Spectra Contoller D-Pad Replacement, D-Pad: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
  5. PowerA Spectra Contoller D-Pad Replacement: step 5, image 1 of 1
    • Gently take the motherboard off of the front plate.
  6. PowerA Spectra Contoller D-Pad Replacement: step 6, image 1 of 1
    • Use Phillips screwdriver to remove the four 7.8 mm screws that secure the D-pad.
  7. PowerA Spectra Contoller D-Pad Replacement: step 7, image 1 of 1
    • Gently pry off the D-pad.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 132
