PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
Faizan Naveed
Faizan Naveed and 2 other contributors
Last updated on May 1, 2022
20 minutes
Moderate
Community-Contributed Guide
iFixit earns commission when you buy through these links.
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: step 1, image 1 of 2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: step 1, image 2 of 2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: step 2, image 1 of 1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: step 3, image 1 of 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: step 3, image 2 of 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: step 3, image 3 of 3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: step 4, image 1 of 1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
13 other people completed this guide.
Faizan Naveed
3,381 Reputation
8 Guides authored
Mobile Device Repair Factory Member of Mobile Device Repair Factory
Business
1 Member
16 Guides authored
5 Comments
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - Reply
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Reply
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Reply
My bettry is too good work but tha wireis want to b change
Asoo Malik - Reply
Plzz tel me how I can change tha wire of my power beats
Asoo Malik - Reply
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 79
All Time: 29,660
