PowerBook G3 Lombard RAM Replacement
  1. PowerBook G3 Lombard RAM Replacement, Keyboard: step 1, image 1 of 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard RAM Replacement: step 2, image 1 of 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard RAM Replacement: step 3, image 1 of 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard RAM Replacement, Heat Shield: step 4, image 1 of 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard RAM Replacement: step 5, image 1 of 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard RAM Replacement: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard RAM Replacement, PRAM Battery: step 7, image 1 of 1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard RAM Replacement: step 8, image 1 of 1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard RAM Replacement, Modem: step 9, image 1 of 1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard RAM Replacement: step 10, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard RAM Replacement: step 11, image 1 of 1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard RAM Replacement: step 12, image 1 of 1
  13. PowerBook G3 Lombard RAM Replacement, Processor: step 13, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard RAM Replacement: step 14, image 1 of 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard RAM Replacement: step 15, image 1 of 1
  16. PowerBook G3 Lombard RAM Replacement, RAM: step 16, image 1 of 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
6 other people completed this guide.
Attached Documents
iRobot
1 Reputation
635 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 8,882
