PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement
  1. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement, Battery: step 1, image 1 of 1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement, RAM: step 2, image 1 of 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement: step 3, image 1 of 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
40 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
One Comment
Why does my computer only show 768mb RAM after the upgrade? 1 RAM slot is the soldered 256mb and the other is 1gb.... Hm...
iamkiyoshi - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 20,111
