PowerBook G4 Aluminum 15" 1-1.5 GHz Airport Extreme Card Replacement
  1. PowerBook G4 Aluminum 15" 1-1.5 GHz Airport Extreme Card Replacement, Battery: step 1, image 1 of 1
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1-1.5 GHz Airport Extreme Card Replacement, Airport Extreme Card: step 2, image 1 of 1
    • Flip down the door on the right side of the battery compartment.
  3. PowerBook G4 Aluminum 15" 1-1.5 GHz Airport Extreme Card Replacement: step 3, image 1 of 1
    • Use a spudger or flathead screwdriver to disconnect the Airport antenna from the card.
  4. PowerBook G4 Aluminum 15" 1-1.5 GHz Airport Extreme Card Replacement: step 4, image 1 of 1
    • Grasp the plastic tab and pull the card out all the way.
14 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 17,468
