PowerBook G4 Titanium Mercury Lower Case Replacement
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
  1. PowerBook G4 Titanium Mercury Lower Case Replacement: step 2, image 1 of 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. PowerBook G4 Titanium Mercury Lower Case Replacement: step 3, image 1 of 1
    • Your laptop should look approximately like this.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 5,287
