PowerLead Puto PLD003 Lens Replacement
  1. PowerLead Puto PLD003 Lens Replacement, Side Panel: step 1, image 1 of 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Lens Replacement: step 2, image 1 of 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Lens Replacement: step 3, image 1 of 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Lens Replacement: step 4, image 1 of 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Lens Replacement, Lens: step 5, image 1 of 2 PowerLead Puto PLD003 Lens Replacement, Lens: step 5, image 2 of 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Lens Replacement: step 6, image 1 of 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Lens Replacement: step 7, image 1 of 1
    • Apply pressure to the back panel (away from the camera) to remove.
  8. PowerLead Puto PLD003 Lens Replacement: step 8, image 1 of 1
    • Set aside back panel for now.
    • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
  9. PowerLead Puto PLD003 Lens Replacement: step 9, image 1 of 1
    • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
    • The white cable should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the lens easier
  10. PowerLead Puto PLD003 Lens Replacement: step 10, image 1 of 1
    • Unscrew the two 4 mm Phillips #1 screws holding onto the lens casing
    • There are also two 4 mm Phillips #1 screws on the other side holding onto the lens casing, remove them as well.
  11. PowerLead Puto PLD003 Lens Replacement: step 11, image 1 of 1
    • Pull forward on the lens casing to remove it. The cord connecting the light to the motherboard should still be attached.
  12. PowerLead Puto PLD003 Lens Replacement: step 12, image 1 of 1
    • Unscrew the three 4 mm Phillips #1 screws holding the plastic lens holder.
  13. PowerLead Puto PLD003 Lens Replacement: step 13, image 1 of 1
    • Remove the plastic lens holder.
  14. PowerLead Puto PLD003 Lens Replacement: step 14, image 1 of 1
    • Push the lens out of the plastic casing from the back.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 281
