PowerMac G4 M5183 Graphics Card Removal
  1. PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. PowerMac G4 M5183 Graphics Card Removal, Graphics Card: step 2, image 1 of 2 PowerMac G4 M5183 Graphics Card Removal, Graphics Card: step 2, image 2 of 2
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
Finish Line
13 other people completed this guide.
Justin Petrilli
3,132 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
37 Guides authored
2 Guide Comments
Do I need to avoid static to protect the board?
Jim Robson - Reply
Es ist eine deutsche Anleitung, aber auf der iFixit Übersicht als Englisch gekennzeichnet.
Toni Makkaroni - Reply
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 47
All Time: 10,172
