PowerMac G4 M5183 RAM
  1. PowerMac G4 M5183 RAM, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 PowerMac G4 M5183 RAM, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. PowerMac G4 M5183 RAM, RAM: step 2, image 1 of 2 PowerMac G4 M5183 RAM, RAM: step 2, image 2 of 2
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
Finish Line
13 other people completed this guide.
Justin Petrilli
3,132 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
37 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 7,111
