PowerShot G7 X Mark II LCD Screen Replacement
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: step 2, image 1 of 1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: step 3, image 1 of 1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: step 4, image 1 of 1
    • The screen is detached and can now be replaced.
4 other people completed this guide.
Brandon
626 Reputation
4 Guides authored
USF Tampa, Team 12-3, Eyestone Spring 2017 Member of USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Members
4 Guides authored
4 Comments
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Reply
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Reply
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Reply
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 104
All Time: 8,224
