Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: step 1, image 1 of 2 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: step 1, image 2 of 2
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 2, image 1 of 1
    • Unplug the tree from the outlet.
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 3, image 1 of 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 3, image 2 of 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 3, image 3 of 3
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 4, image 1 of 1
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 5, image 1 of 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 5, image 2 of 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 5, image 3 of 3
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 6, image 1 of 1
    • Plug the tree back into the outlet.
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: step 7, image 1 of 1
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
Thank you for using this guide!
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,215
