Presto PopLite 04820 Motor Replacement
  1. Presto PopLite 04820 Motor Replacement, Baseplate: step 1, image 1 of 1
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Presto PopLite 04820 Motor Replacement: step 2, image 1 of 3 Presto PopLite 04820 Motor Replacement: step 2, image 2 of 3 Presto PopLite 04820 Motor Replacement: step 2, image 3 of 3
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Presto PopLite 04820 Motor Replacement, Motor: step 3, image 1 of 2 Presto PopLite 04820 Motor Replacement, Motor: step 3, image 2 of 2
    • Unscrew the four 13mm Phillips #2 screws but do not remove completely just yet.
  4. Presto PopLite 04820 Motor Replacement: step 4, image 1 of 2 Presto PopLite 04820 Motor Replacement: step 4, image 2 of 2
    • Locate the two twist-on wire connectors.
    • Unscrew the two caps and keep track of the wires that wire up together to make it easier in the end to put back together.
  5. Presto PopLite 04820 Motor Replacement: step 5, image 1 of 3 Presto PopLite 04820 Motor Replacement: step 5, image 2 of 3 Presto PopLite 04820 Motor Replacement: step 5, image 3 of 3
    • Pull the entire cavity out of the popper that holds the motor.
    • Remove the popping chamber base.
  6. Presto PopLite 04820 Motor Replacement: step 6, image 1 of 2 Presto PopLite 04820 Motor Replacement: step 6, image 2 of 2
    • Remove circuit board from the motor base holder.
    • Make sure these 3 wires are securely placed inside grooves when reassembling the motor base holder.
  7. Presto PopLite 04820 Motor Replacement: step 7, image 1 of 2 Presto PopLite 04820 Motor Replacement: step 7, image 2 of 2
    • Remove the orange twist-on wire connector connecting the black wire to the grey wire.
  8. Presto PopLite 04820 Motor Replacement: step 8, image 1 of 2 Presto PopLite 04820 Motor Replacement: step 8, image 2 of 2
    • Locate the clear plastic motor fan.
    • Grab hold of the motor and pull upwards to pop the motor fan off of the needle that connects to the motor.
    • This may require large amounts of force to pull it off the needle.
  9. Presto PopLite 04820 Motor Replacement: step 9, image 1 of 3 Presto PopLite 04820 Motor Replacement: step 9, image 2 of 3 Presto PopLite 04820 Motor Replacement: step 9, image 3 of 3
    • Remove the two 4 mm Phillips #00 screws.
    • Once the screws are removed, the motor should drop down.
    • Now remove the motor base to expose the motor.
  10. Presto PopLite 04820 Motor Replacement: step 10, image 1 of 2 Presto PopLite 04820 Motor Replacement: step 10, image 2 of 2
    • This is the motor.
    • Now replace it with your new one!
4 other people completed this guide.
Emanuele Rocco
694 Reputation
6 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2015 Member of USF Tampa, Team 2-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G5
2 Members
6 Guides authored
One Comment
What new motor? Where do we get said motor, and what are the motor specs? What about installing the bridge rectifier on the new motor? A 3rd party supplier is not likely to sell these motors with the rectifier pre-installed.
Bill Richardson - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 2,665
