Presto PopLite 04820 Popping Chamber Base Replacement
  1. Presto PopLite 04820 Popping Chamber Base Replacement, Baseplate: step 1, image 1 of 1
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Presto PopLite 04820 Popping Chamber Base Replacement: step 2, image 1 of 3 Presto PopLite 04820 Popping Chamber Base Replacement: step 2, image 2 of 3 Presto PopLite 04820 Popping Chamber Base Replacement: step 2, image 3 of 3
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Presto PopLite 04820 Popping Chamber Base Replacement, Popping Chamber Base: step 3, image 1 of 2 Presto PopLite 04820 Popping Chamber Base Replacement, Popping Chamber Base: step 3, image 2 of 2
    • Remove the four 13 mm Phillips #2 screws.
  4. Presto PopLite 04820 Popping Chamber Base Replacement: step 4, image 1 of 1
    • Remove the entire cavity that holds the motor from the base of the PopLite.
    • Be gentle while taking the motor out of the base to avoid wire damage.
  5. Presto PopLite 04820 Popping Chamber Base Replacement: step 5, image 1 of 2 Presto PopLite 04820 Popping Chamber Base Replacement: step 5, image 2 of 2
    • Turn the popping chamber base sideways.
    • Now remove popping chamber base.
Emanuele Rocco
694 Reputation
6 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2015 Member of USF Tampa, Team 2-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G5
2 Members
6 Guides authored
One Comment
Where can I get the new base from?
Barry - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 640
