Presto PopLite 04820 Popping Chamber Shaft Replacement
  1. Presto PopLite 04820 Popping Chamber Shaft Replacement, Chute: step 1, image 1 of 1
    • Make sure you unplug the device before disassembling.
    • Remove the butter melter/measuring cup.
  2. Presto PopLite 04820 Popping Chamber Shaft Replacement: step 2, image 1 of 1
    • Remove the cover.
  3. Presto PopLite 04820 Popping Chamber Shaft Replacement: step 3, image 1 of 3 Presto PopLite 04820 Popping Chamber Shaft Replacement: step 3, image 2 of 3 Presto PopLite 04820 Popping Chamber Shaft Replacement: step 3, image 3 of 3
    • Remove the three 49 mm Phillips #2 screws.
    • Once you have removed the screws, remove the chute from popper base.
  4. Presto PopLite 04820 Popping Chamber Shaft Replacement, Popping Chamber Shaft: step 4, image 1 of 1
    • The popping chamber shaft should be located in the popper base once the chute is removed.
  5. Presto PopLite 04820 Popping Chamber Shaft Replacement: step 5, image 1 of 2 Presto PopLite 04820 Popping Chamber Shaft Replacement: step 5, image 2 of 2
    • Reach down the popper base and grab the popping chamber shaft. Begin to remove it from the popper base.
    • Now remove it completely and set it aside for new shaft to be placed.
Emanuele Rocco
694 Reputation
6 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2015 Member of USF Tampa, Team 2-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G5
2 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 376
