ProLine HB25 Disassembly
  1. ProLine HB25 Disassembly, ProLine HB25 Disassembly: step 1, image 1 of 1
    • Unscrew the screw on the back of the product.
  2. ProLine HB25 Disassembly: step 2, image 1 of 2 ProLine HB25 Disassembly: step 2, image 2 of 2
    • Pull out the backtab of the housing.
    • Push in the snapfits with, for instance, a screwdriver.
  3. ProLine HB25 Disassembly: step 3, image 1 of 2 ProLine HB25 Disassembly: step 3, image 2 of 2
    • Separate the housing with calibrated force.
    • Keep your fingers away from the housing and do not bend or break the housing.
    • Use a flathead screwdriver to push out the lower function button.
    • Remove the separating device.
  4. ProLine HB25 Disassembly: step 4, image 1 of 1
    • Unscrew the hidden screw under the button.
  5. ProLine HB25 Disassembly: step 5, image 1 of 2 ProLine HB25 Disassembly: step 5, image 2 of 2
    • Open the housing.
    • Unscrew the circuit board.
    • Unscrew the wire lock.
  6. ProLine HB25 Disassembly: step 6, image 1 of 2 ProLine HB25 Disassembly: step 6, image 2 of 2
    • Push the housing of the button out of the housing.
  7. ProLine HB25 Disassembly: step 7, image 1 of 2 ProLine HB25 Disassembly: step 7, image 2 of 2
    • Push on the side of the housing of the button to push the button out of the housing.
    • The spring can jump away when you push out the button.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 286
