Introduction
This is the motherboard replacement guide. If you have found that there are issues with the motherboard, use this replacement guide
Make sure device is unplugged and turned off while working on the device.
Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
Remove the 3 black pieces of tape from the device.
Remove the 5 yellow pieces of tape from the device.
Almost done!
