ProScan PLT7050 Speaker Replacement
  1. ProScan PLT7050 Speaker Replacement, Open Device: step 1, image 1 of 1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Speaker Replacement: step 2, image 1 of 1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the yellow tape.
  4. ProScan PLT7050 Speaker Replacement: step 4, image 1 of 2 ProScan PLT7050 Speaker Replacement: step 4, image 2 of 2
    • Use the soldering tool to remove the two speaker wires from the mother board.
    • Take note of where the wires are located.
    • Soldering tool will get hot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 177
