ProScan PLT7223G Speakers Replacement
  1. ProScan PLT7223G Speakers Replacement, Speakers: step 1, image 1 of 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Speakers Replacement: step 2, image 1 of 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Speakers Replacement: step 3, image 1 of 1
    • Pull back the protective tape from the two wires that connect the speakers to the motherboard.
  4. ProScan PLT7223G Speakers Replacement: step 4, image 1 of 1
    • Use the soldering tool to remove speaker wires from motherboard.
    • Soldering tool will get hot, handle with care.
  5. ProScan PLT7223G Speakers Replacement: step 5, image 1 of 2 ProScan PLT7223G Speakers Replacement: step 5, image 2 of 2
    • If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 327
