Introduction
A damaged spring can lead to issues with the toaster lever being fully locked in and released. When the lever is released it should be able to move freely in an upward direction. When the lever is being pushed down, it should move smoothly with slight resistance from the spring.
Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
