ProfiMixx 44 Disassembly
  1. ProfiMixx 44 Disassembly, Removing the scrapers: step 1, image 1 of 3 ProfiMixx 44 Disassembly, Removing the scrapers: step 1, image 2 of 3 ProfiMixx 44 Disassembly, Removing the scrapers: step 1, image 3 of 3
    • Removing the five (TR15) scrapers
  2. ProfiMixx 44 Disassembly, Removing the housing: step 2, image 1 of 2 ProfiMixx 44 Disassembly, Removing the housing: step 2, image 2 of 2
    • Removing the first part of the housing
    • Removing the rotary wheel, important pay attention to the black component so that the nose in does not break off (green mark).
    • Removing the second part of the housing
  3. ProfiMixx 44 Disassembly, Assembly of the housing I: step 3, image 1 of 3 ProfiMixx 44 Disassembly, Assembly of the housing I: step 3, image 2 of 3 ProfiMixx 44 Disassembly, Assembly of the housing I: step 3, image 3 of 3
    • Make sure that the green marked elements are in the right place in both housings, the red element is only available once.
    • Make sure that the two strands run as marked in blue.
    • The white element must be in the rear position. (marked in orange)
  4. ProfiMixx 44 Disassembly, Assembly of the housing II: step 4, image 1 of 3 ProfiMixx 44 Disassembly, Assembly of the housing II: step 4, image 2 of 3 ProfiMixx 44 Disassembly, Assembly of the housing II: step 4, image 3 of 3
    • Lift the motor-gearbox-unit a little bit upwards so that you can insert the black element with the nose into the hole of the white element. (marked in green)
    • Insert the nose of the black element into the hole of the rotary switch, making sure it is oriented as shown.
    • Gently move the rotary switch so that it fits into the slot in the housing. (marked in blue)
    • Then you can tighten the upper housing part with the five screws (TR15).
Finish Line
Justus Klingler
531 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 72
All Time: 1,548
