Projector NEC VT660 Disassembly
  1. Projector NEC VT660 Disassembly, Remove lamp cover: step 1, image 1 of 2 Projector NEC VT660 Disassembly, Remove lamp cover: step 1, image 2 of 2
    • Unscrew the screw and remove the cover.
  2. Projector NEC VT660 Disassembly, Remove lamp: step 2, image 1 of 2 Projector NEC VT660 Disassembly, Remove lamp: step 2, image 2 of 2
    • Unscrew the two screws that are holding the lamp in place.
    • Pull the lamp out.
  3. Projector NEC VT660 Disassembly, Housing disassembly: step 3, image 1 of 3 Projector NEC VT660 Disassembly, Housing disassembly: step 3, image 2 of 3 Projector NEC VT660 Disassembly, Housing disassembly: step 3, image 3 of 3
    • Remove 5 screws from the bottom.
    • Remove 1 screw from the back.
    • Slowly lift the upper housing and disconnect the connector.
    • Do not lift the upper housing too quickly as it could damage the connector cable.
  4. Projector NEC VT660 Disassembly, Removing fan: step 4, image 1 of 3 Projector NEC VT660 Disassembly, Removing fan: step 4, image 2 of 3 Projector NEC VT660 Disassembly, Removing fan: step 4, image 3 of 3
    • After removing the upper housing. Turn the projector to see the fan.
    • Unscrew two screws from each side of the fan holder.
    • Remove the fan from holder by unscrewing the two screws.
    • Carefully take out the fan. Keep an eye on the wires that go through the holder.
Attached Documents
Klemen Hodžić
694 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 293
