Promowide SP1790 Charging Port Replacement
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: step 1, image 1 of 1
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: step 2, image 1 of 1
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: step 3, image 1 of 1
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: step 4, image 1 of 1
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: step 5, image 1 of 1
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: step 6, image 1 of 1
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: step 7, image 1 of 1
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: step 8, image 1 of 1
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: step 9, image 1 of 1
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 949
