ProntoTec Axius Screen Replacement
  1. ProntoTec Axius Screen Replacement, Screen: step 1, image 1 of 1
    • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Screen Replacement: step 2, image 1 of 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Screen Replacement: step 3, image 1 of 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Screen Replacement: step 4, image 1 of 1
    • Remove all of the yellow tape that is on the device with the spudger.
    • Be careful not to cut any wires that are under the tapes.
  5. ProntoTec Axius Screen Replacement: step 5, image 1 of 2 ProntoTec Axius Screen Replacement: step 5, image 2 of 2
    • Use the flat end of the spudger to gently pry the battery from the back of the screen.
  6. ProntoTec Axius Screen Replacement: step 6, image 1 of 2 ProntoTec Axius Screen Replacement: step 6, image 2 of 2
    • Use a spudger to lift all the ribbon cable clamps
    • Detach all three ribbon cables from the clamps
  7. ProntoTec Axius Screen Replacement: step 7, image 1 of 3 ProntoTec Axius Screen Replacement: step 7, image 2 of 3 ProntoTec Axius Screen Replacement: step 7, image 3 of 3
    • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
  8. ProntoTec Axius Screen Replacement: step 8, image 1 of 3 ProntoTec Axius Screen Replacement: step 8, image 2 of 3 ProntoTec Axius Screen Replacement: step 8, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
    • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
  9. ProntoTec Axius Screen Replacement: step 9, image 1 of 1
    • Remove the orange tab from the back of the screen as shown in the picture
  10. ProntoTec Axius Screen Replacement: step 10, image 1 of 2 ProntoTec Axius Screen Replacement: step 10, image 2 of 2
    • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
Antonio Irons
441 Reputation
4 Guides authored
UMass Dartmouth, Team 5-3, Martin Fall 2016 Member of UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 405
