You're viewing a previously published version of this guide.  View latest version
Older Newer
Propel Graviton Rotor Assembly Replacement
Kyle Mott
Kyle Mott and 3 other contributors
Last updated on May 7, 2024
15 - 30 minutes
Easy
Needs More Images
Missing Steps
Introduction
Go to step 1
When drones crash into obstacles or the ground, parts can be damaged. Debris (any foreign material) may become lodged in gears and cause them to break, or blunt force may damage them.
If your drone’s rotor assembly isn’t functioning properly because of damaged or dirty parts, then this guide is for you.
All four of the drone’s rotor assemblies are the same (minus the camber of the propellers, two of which are labeled A and the other two, B). This guide can be used to repair any of these by replacing their broken components.
Tools
Show more…
  1. Propel Graviton Rotor Assembly Replacement, Rotor Assembly: step 1, image 1 of 2 Propel Graviton Rotor Assembly Replacement, Rotor Assembly: step 1, image 2 of 2
    • Remove the battery.
  2. Propel Graviton Rotor Assembly Replacement: step 2, image 1 of 1
    • Remove the 4mm screw that holds the propeller to the axle using a Phillips #00 screwdriver.
    • When re-assembling your drone, be careful not to over tighten the screws. The drone body is made of soft plastic, doing so may strip the screws' housing and prevent them from holding.
    • Remove the propeller by pulling it upwards away from the assembly.
  3. Propel Graviton Rotor Assembly Replacement: step 3, image 1 of 2 Propel Graviton Rotor Assembly Replacement: step 3, image 2 of 2
    Tool used on this step:
    • Remove the three 6mm screws holding the propeller guard with a Phillips #00 screwdriver
    • The drone motor may be magnetized, making it difficult to remove or install the screws. Using the tweezers to grip them is recommended.
  4. Propel Graviton Rotor Assembly Replacement: step 4, image 1 of 1
    • Using your finger, gently push on the top of the propeller axle and remove out of the bottom of its housing.
    • Ensure the axle is cleared of debris.
  5. Propel Graviton Rotor Assembly Replacement: step 5, image 1 of 2 Propel Graviton Rotor Assembly Replacement: step 5, image 2 of 2
    • Remove the wheel bearing from the axle using your fingers.
    • Remove the wheel bearing from the axle housing with a pair of tweezers.
    • Ensure the axle housing is clear of debris.
  6. Propel Graviton Rotor Assembly Replacement: step 6, image 1 of 1
    • Remove the three 6mm screws with a Phillips #00 screwdriver.
    • Some of the screws may not completely remove from the black housing. A slight tap may jar them loose, but this is not necessary.
  7. Propel Graviton Rotor Assembly Replacement: step 7, image 1 of 2 Propel Graviton Rotor Assembly Replacement: step 7, image 2 of 2
    • Gently pry the top and bottom drone housing apart with a spudger to reveal the motor.
    • Ensure the housing is cleared of debris.
    • Replace the motor (if it is necessary).
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 545
