Protocol Dronium III AP Camera Replacement
  1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: step 1, image 1 of 2 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: step 1, image 2 of 2
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Camera Replacement: step 2, image 1 of 1
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Camera Replacement: step 3, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 3, image 2 of 2
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Camera Replacement, Camera: step 4, image 1 of 1
    • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
  5. Protocol Dronium III AP Camera Replacement: step 5, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 5, image 2 of 2
    • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Camera Replacement: step 6, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 6, image 2 of 2
    • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Camera Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the tape covering the camera with the tweezers.
  8. Protocol Dronium III AP Camera Replacement: step 8, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 8, image 2 of 2
    • Remove the plastic holding the ribbon cable connector with the tweezers.
    • Be careful with the ribbon cable, it is easy to damage.
  9. Protocol Dronium III AP Camera Replacement: step 9, image 1 of 1
    • Move the ribbon cable out of the way with the Spuger.
  10. Protocol Dronium III AP Camera Replacement: step 10, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 10, image 2 of 2
    • Remove the camera by gently prying it out of the bracket with the spudger.
Steven Mooers
401 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Rose Fall 2017 Member of UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 305
