Protocol Dronium Two Rotor Blade Replacement
  1. Protocol Dronium Two Rotor Blade Replacement, Rotor Blade: step 1, image 1 of 1
    • Turn off the drone by pushing the selector switch to the left.
  2. Protocol Dronium Two Rotor Blade Replacement: step 2, image 1 of 2 Protocol Dronium Two Rotor Blade Replacement: step 2, image 2 of 2
    • Using the Phillips screwdriver included with the drone, carefully remove the 4.02 mm rotor blade screw.
    • Once the screw is removed, remove the rotor blade by lifting the blade straight off of the drone
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 285
