Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: step 1, image 1 of 2 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: step 1, image 2 of 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: step 2, image 1 of 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): step 3, image 1 of 1
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: step 4, image 1 of 1
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: step 5, image 1 of 1
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Matthew Selting
432 Reputation
4 Guides authored
UW Stout, Team S8-G4, Ogden Spring 2018 Member of UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 159
