Protocol Galileo Stealth Pinion Gear Replacement
  1. Protocol Galileo Stealth Pinion Gear Replacement, Propeller: step 1, image 1 of 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Pinion Gear Replacement: step 2, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Pinion Gear Replacement: step 3, image 1 of 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Pinion Gear Replacement: step 4, image 1 of 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Pinion Gear Replacement, Housing: step 5, image 1 of 2 Protocol Galileo Stealth Pinion Gear Replacement, Housing: step 5, image 2 of 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Pinion Gear Replacement: step 6, image 1 of 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Pinion Gear Replacement, Pinion Gear: step 7, image 1 of 1
    • Lift the pinion gear off the motor shaft by lightly pulling it away from the drone.
Matthew Selting
432 Reputation
4 Guides authored
UW Stout, Team S8-G4, Ogden Spring 2018 Member of UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Members
6 Guides authored
2 Comments
where can i get pinion gears at
steve Litchfield - Reply
where can i purchase pinion gears
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 231
