Protocol Galileo Stealth Propeller Replacement
  1. Protocol Galileo Stealth Propeller Replacement, Propeller: step 1, image 1 of 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Propeller Replacement: step 2, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Propeller Replacement: step 3, image 1 of 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Propeller Replacement: step 4, image 1 of 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
stephen R masalewicz
270 Reputation
2 Guides authored
UW Stout, Team S8-G4, Ogden Spring 2018 Member of UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 389
