Protocol Neo-Drone AP Controller Switch Replacement
  1. Protocol Neo-Drone AP Controller Switch Replacement, Controller Switch: step 1, image 1 of 2 Protocol Neo-Drone AP Controller Switch Replacement, Controller Switch: step 1, image 2 of 2
    • Remove the single 6.5mm Phillips #1 screw from the battery cover.
    • Remove the three AAA batteries.
  2. Protocol Neo-Drone AP Controller Switch Replacement: step 2, image 1 of 2 Protocol Neo-Drone AP Controller Switch Replacement: step 2, image 2 of 2
    • Remove seven 6.5mm Phillips #1 screws from the back panel.
    • Pull the back panel up to separate it from the front panel.
  3. Protocol Neo-Drone AP Controller Switch Replacement: step 3, image 1 of 2 Protocol Neo-Drone AP Controller Switch Replacement: step 3, image 2 of 2
    • Remove three 4.5mm Phillips #1 screws from the motherboard.
    • Pull the motherboard out of the case.
  4. Protocol Neo-Drone AP Controller Switch Replacement: step 4, image 1 of 2 Protocol Neo-Drone AP Controller Switch Replacement: step 4, image 2 of 2
    • Here is a link to the iFixit Soldering Guide
    • Use a soldering iron to remove the solder form the motherboard.
Andrew
291 Reputation
2 Guides authored
IUPUI, Team S2-G3, Harley Summer 2018 Member of IUPUI, Team S2-G3, Harley Summer 2018
IUPUI-HARLEY-SU18S2G3
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 239
