Protocol Neo-Drone AP Motor Replacement
  1. Protocol Neo-Drone AP Motor Replacement, Motor: step 1, image 1 of 2 Protocol Neo-Drone AP Motor Replacement, Motor: step 1, image 2 of 2
    • Remove the four blades by pulling them off of the motors.
  2. Protocol Neo-Drone AP Motor Replacement: step 2, image 1 of 1
    • Remove the blade guards by pushing the guards downward towards the padded feet.
  3. Protocol Neo-Drone AP Motor Replacement: step 3, image 1 of 1
    • Remove the four 4.5mm Phillips #0 screws from the back panel.
  4. Protocol Neo-Drone AP Motor Replacement: step 4, image 1 of 2 Protocol Neo-Drone AP Motor Replacement: step 4, image 2 of 2
    • Use the flat end of a spudger to pry apart the the two pieces.
    • Lift the back panel up to separate it from the front panel.
  5. Protocol Neo-Drone AP Motor Replacement: step 5, image 1 of 1
    • Pull the four motors out of the case.
    • The motors are still soldered to the motherboard.
  6. Protocol Neo-Drone AP Motor Replacement: step 6, image 1 of 1
    • Here is a link to the iFixit Soldering Guide
    • Use a soldering iron to desolder the motors from the motherboard.
Andrew
291 Reputation
2 Guides authored
IUPUI, Team S2-G3, Harley Summer 2018 Member of IUPUI, Team S2-G3, Harley Summer 2018
IUPUI-HARLEY-SU18S2G3
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 421
