Protocol Slipstream EVO Propeller Guards Replacement
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: step 1, image 1 of 1
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: step 2, image 1 of 2 Protocol Slipstream EVO Propeller Guards Replacement: step 2, image 2 of 2
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: step 3, image 1 of 2 Protocol Slipstream EVO Propeller Guards Replacement: step 3, image 2 of 2
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
Michael Dang
301 Reputation
3 Guides authored
UW Tacoma, Team S3-G3, Liner Spring 2017 Member of UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 178
