Protocol Slipstream EVO Propeller blades Replacement
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: step 1, image 1 of 1
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: step 2, image 1 of 2 Protocol Slipstream EVO Propeller blades Replacement: step 2, image 2 of 2
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: step 3, image 1 of 3 Protocol Slipstream EVO Propeller blades Replacement: step 3, image 2 of 3 Protocol Slipstream EVO Propeller blades Replacement: step 3, image 3 of 3
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
Michael Dang
301 Reputation
3 Guides authored
UW Tacoma, Team S3-G3, Liner Spring 2017 Member of UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 550
