Protocol TerraCopter EVO Front Wheels Replacement
  1. Protocol TerraCopter EVO Front Wheels Replacement, Propellers: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the four screws connecting the propellers to the device.
  2. Protocol TerraCopter EVO Front Wheels Replacement: step 2, image 1 of 2 Protocol TerraCopter EVO Front Wheels Replacement: step 2, image 2 of 2
    • Hold the propellers gently and pull the propellers out of the drone .
  3. Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: step 3, image 1 of 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: step 3, image 2 of 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: step 3, image 3 of 3
    • Use a plastic opening tool or a spudger to separate the drone's cover from the body of the drone.
    • Remove the connector of the drone body and the back wheels using a plastic opening tool.
  4. Protocol TerraCopter EVO Front Wheels Replacement: step 4, image 1 of 2 Protocol TerraCopter EVO Front Wheels Replacement: step 4, image 2 of 2
    • Use the opening tool to separate the drone's body from the drone's shock absorber.
  5. Protocol TerraCopter EVO Front Wheels Replacement: step 5, image 1 of 3 Protocol TerraCopter EVO Front Wheels Replacement: step 5, image 2 of 3 Protocol TerraCopter EVO Front Wheels Replacement: step 5, image 3 of 3
    • Hold the wheels gently then pull it out of the drone's lower board wheels connector.
    • Repeat the same step for the other front wheel.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 135
