Protocol Videodrone AP Propeller Motors Replacement
  1. Protocol Videodrone AP Propeller Motors Replacement, Propeller Motors: step 1, image 1 of 1
    • Power off the drone before proceeding with the rest of the guide.
  2. Protocol Videodrone AP Propeller Motors Replacement: step 2, image 1 of 1
    • Use the Phillips #0 screwdriver to remove four propeller screws.
    • If you don't own the screwdriver included with the drone kit, use a Phillips #0 screwdriver.
  3. Protocol Videodrone AP Propeller Motors Replacement: step 3, image 1 of 2 Protocol Videodrone AP Propeller Motors Replacement: step 3, image 2 of 2
    • Use the Phillips #0 screwdriver to remove eight propeller guard screws.
  4. Protocol Videodrone AP Propeller Motors Replacement: step 4, image 1 of 2 Protocol Videodrone AP Propeller Motors Replacement: step 4, image 2 of 2
    • Use the Phillips #0 screwdriver to remove eight housing screws from the bottom of the drone.
  5. Protocol Videodrone AP Propeller Motors Replacement: step 5, image 1 of 1
    • Open up housing to reveal main circuit board.
  6. Protocol Videodrone AP Propeller Motors Replacement: step 6, image 1 of 2 Protocol Videodrone AP Propeller Motors Replacement: step 6, image 2 of 2
    • Use the Phillips #0 screwdriver to remove three motor housing screws. There are three screws per motor.
    • The plastic housing is glued directly to motor.
  7. Protocol Videodrone AP Propeller Motors Replacement: step 7, image 1 of 3 Protocol Videodrone AP Propeller Motors Replacement: step 7, image 2 of 3 Protocol Videodrone AP Propeller Motors Replacement: step 7, image 3 of 3
    • Desolder the wires connecting the propeller motor to the motherboard (2 per motor) and remove the motor from the device.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
2 other people completed this guide.
Karan Paranganat
352 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Fall 2019 Member of IUPUI, Team S2-G2, Harley Fall 2019
IUPUI-HARLEY-F19S2G2
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 275
