Zeal Optics iON Viewfinder Lens Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Zeal Optics iON Viewfinder Lens Assembly Replacement, Viewfinder Lens Assembly: step 1, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement, Viewfinder Lens Assembly: step 1, image 2 of 2
    • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
    • Flip the viewfinder housing over 180 degrees.
    • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
  2. Zeal Optics iON Viewfinder Lens Assembly Replacement: step 2, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement: step 2, image 2 of 2
    • Pull the two halves of the viewfinder housing apart.
  3. Zeal Optics iON Viewfinder Lens Assembly Replacement: step 3, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Be sure to pry up on the hinged flap, not the connector itself.
  4. Zeal Optics iON Viewfinder Lens Assembly Replacement: step 4, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement: step 4, image 2 of 2
    • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
  5. Zeal Optics iON Viewfinder Lens Assembly Replacement: step 5, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
  6. Zeal Optics iON Viewfinder Lens Assembly Replacement: step 6, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement: step 6, image 2 of 2
    • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
  7. Zeal Optics iON Viewfinder Lens Assembly Replacement: step 7, image 1 of 2 Zeal Optics iON Viewfinder Lens Assembly Replacement: step 7, image 2 of 2
    • Remove the viewfinder lens assembly from the viewfinder housing.
Eric Flores
128 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 278
