Introduction
This guide will explain how to remove and replace the internal battery in the Puritan Bennett 560 ventilator.
Warnings:
- Ensure the ventilator is powered off and AC power is disconnected
- Do not try to open the battery itself under any circumstances
- Cover the battery terminals with a non-conductive material when not in use to prevent short-circuiting.
The repair information is also available on pages 143-144 (Section 5, Pages 13-14) of the Service Manual that is linked in the documents section.
REPLACEMENT
Install the battery into cover, as shown in figure.
Make sure the contacts on the battery line up with those in the ventilator.
Slide the battery and cover together into the housing.
While applying pressure to the cover, install the two rear screws.
Install the screw at the bottom of the cover.
Be careful not to over-tighten any screws.
2 other people completed this guide.
One Comment
I can’t seem to edit the step titles. They should show:
Step 1: Battery Removal
Step 2:
Step 3: Battery Replacement
