Puritan Bennett 840 BPS Battery Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Puritan Bennett 840 BPS Battery Replacement, BPS Battery: step 1, image 1 of 2 Puritan Bennett 840 BPS Battery Replacement, BPS Battery: step 1, image 2 of 2
    • Before beginning, ensure that the battery is drained and the ventilator is not connected to a power source.
    • Locate the breath delivery unit (BDU) shelf on the ventilator.
    • Locate the battery indicator label on the shelf to determine whether the BPS battery holds a one-hour or four-hour charge - the default for this guide is a four-hour battery.
  2. Puritan Bennett 840 BPS Battery Replacement: step 2, image 1 of 1
    • Grasp the sides of the front bezel of the BPU and gently spread them away from the ventilator.
    • Pull the bezel outward to remove it from the cart.
    • Use a Phillips screwdriver to remove the two screws that connect the BPS to the BDU shelf at the back of the cart.
  3. Puritan Bennett 840 BPS Battery Replacement: step 3, image 1 of 1
    • Using a Phillips screwdriver, remove the eleven screws securing the BPS top and front metal covers.
    • If the BPS contains a one-hour battery, only the four screws holding the one-hour battery shield (four on the top cover) need to be removed.
    • Pull the covers away from the BPS.
  4. Puritan Bennett 840 BPS Battery Replacement: step 4, image 1 of 3 Puritan Bennett 840 BPS Battery Replacement: step 4, image 2 of 3 Puritan Bennett 840 BPS Battery Replacement: step 4, image 3 of 3
    • Locate the battery indicator bracket.
    • Cut the zip tie connecting the battery harness (bundle of wires coming from the battery) to the battery indicator bracket.
    • If the ventilator contains a one-hour battery, simply disconnect the battery harness from the battery cable and lift the battery out of the BPS.
  5. Puritan Bennett 840 BPS Battery Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the two screws securing the battery retaining bracket to the rear of the BPS.
  6. Puritan Bennett 840 BPS Battery Replacement: step 6, image 1 of 1
    • Disconnect the battery connector from J2 on the circuit board next to the battery indicator bracket.
  7. Puritan Bennett 840 BPS Battery Replacement: step 7, image 1 of 1
    • Using a Phillips screwdriver, loosen the two side screws and the two base screws holding the BPS front bracket.
    • Carefully lift the battery out of the BPS.
2 other people completed this guide.
Olivia May
600 Reputation
1 Guide authored
Cal Poly, Team S7-G4, Paton Spring 2020 Member of Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 32
All Time: 1,107
