Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement, Children/Adult Expiratory Filter: step 1, image 1 of 1
    • Do not begin process while patient is connected. Alarm will sound
    • If necessary, remove the expiratory limb (item 4) of the patient circuit from the exhalation filter.
  2. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: step 2, image 1 of 1
    • Raise the exhalation filter latch to unlock (item 3).
  3. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: step 3, image 1 of 1
    • Open the exhalation filter door (item 4).
    • Remove the existing filter. Dispose of properly as per institution’s guidelines on disposing hazardous waste.
  4. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: step 5, image 1 of 1
    • Ensure filter is properly attached to ventilator
    • Only use filters designed for Puritan Bennett 980 Series Ventilator
    • Insert the new filter by sliding the filter along the tracks in the door. Ensure the from patient port (item 6) aligns with the cutout in the door and points away from the ventilator.
    • Note: The condensate vial (item 5) is removable for discarding accumulated liquid. Turn this vial clockwise to remove. Turn this vial counterclockwise to install.
  5. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: step 6, image 1 of 1
    • Close the exhalation filter door (item 4).
  6. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: step 7, image 1 of 1
    • Lower the exhalation filter latch to secure the filter (item 3).
Finish Line
Silvia Calinov
175 Reputation
1 Guide authored
Cal Poly, Team S11-G14, Paton Spring 2020 Member of Cal Poly, Team S11-G14, Paton Spring 2020
CPSU-PATON-S20S11G14
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 31
All Time: 1,380
