Purple SmartVP Camera Replacement
  1. Purple SmartVP Camera Replacement, Camera: step 1, image 1 of 2 Purple SmartVP Camera Replacement, Camera: step 1, image 2 of 2
    • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
  2. Purple SmartVP Camera Replacement: step 2, image 1 of 2 Purple SmartVP Camera Replacement: step 2, image 2 of 2
    • Remove the 1.2 cm hex T9 screws and gently open up the device.
  3. Purple SmartVP Camera Replacement: step 3, image 1 of 2 Purple SmartVP Camera Replacement: step 3, image 2 of 2
    • Detach the camera cover from the motherboard. Be very careful to not damage any of the components on the motherboard.
  4. Purple SmartVP Camera Replacement: step 4, image 1 of 2 Purple SmartVP Camera Replacement: step 4, image 2 of 2
    • Use a plastic spudger to push the black sliding cable connector away from the white bracket.
  5. Purple SmartVP Camera Replacement: step 5, image 1 of 1
    • Gently remove the ribbon cable from the connector.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 212
