Pyle Astro PTBL7C Power Button Replacement
  1. Pyle Astro PTBL7C Power Button Replacement, Power Button: step 1, image 1 of 2 Pyle Astro PTBL7C Power Button Replacement, Power Button: step 1, image 2 of 2
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C Power Button Replacement: step 2, image 1 of 2 Pyle Astro PTBL7C Power Button Replacement: step 2, image 2 of 2
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C Power Button Replacement: step 3, image 1 of 1
  4. Pyle Astro PTBL7C Power Button Replacement: step 4, image 1 of 1
Andrew Redifer
265 Reputation
2 Guides authored
IUPUI, Team S3-G6, Harley Spring 2018 Member of IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 252
