Quantum XTR05 Pinion Gear Replacement
  1. Quantum XTR05 Pinion Gear Replacement, Pinion Gear: step 1, image 1 of 3 Quantum XTR05 Pinion Gear Replacement, Pinion Gear: step 1, image 2 of 3 Quantum XTR05 Pinion Gear Replacement, Pinion Gear: step 1, image 3 of 3
    • Unscrew by turning the cap counter-clockwise until it is separated from the spinning reel.
  2. Quantum XTR05 Pinion Gear Replacement: step 2, image 1 of 3 Quantum XTR05 Pinion Gear Replacement: step 2, image 2 of 3 Quantum XTR05 Pinion Gear Replacement: step 2, image 3 of 3
    • Remove the spool line completely by pulling it away from the reel body.
  3. Quantum XTR05 Pinion Gear Replacement: step 3, image 1 of 3 Quantum XTR05 Pinion Gear Replacement: step 3, image 2 of 3 Quantum XTR05 Pinion Gear Replacement: step 3, image 3 of 3
    • Remove the gear by pulling it up and off of the pinion.
    • Replace the pinion gear with your new one by aligning the shape of the gear opening and the pinion.
  4. Quantum XTR05 Pinion Gear Replacement: step 4, image 1 of 2 Quantum XTR05 Pinion Gear Replacement: step 4, image 2 of 2
    • Place the spool back onto the pinion.
    • Ensure that the spool is fitted properly.
  5. Quantum XTR05 Pinion Gear Replacement: step 5, image 1 of 1
    • Place the spool release and drag adjustment piece back onto the top of the pinion.
  6. Quantum XTR05 Pinion Gear Replacement: step 6, image 1 of 1
    • Screw the spool release and drag adjustment back into place in a clockwise direction until desired tension is achieved.
Finish Line
Nicholas Lynch
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 204
