Quiksilver The Fifty50 Analog Battery Replacement
  1. Quiksilver The Fifty50 Analog Battery Replacement, Strap: step 1, image 1 of 2 Quiksilver The Fifty50 Analog Battery Replacement, Strap: step 1, image 2 of 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Analog Battery Replacement: step 2, image 1 of 2 Quiksilver The Fifty50 Analog Battery Replacement: step 2, image 2 of 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: step 3, image 1 of 2 Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: step 3, image 2 of 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Analog Battery Replacement: step 4, image 1 of 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: step 5, image 1 of 2 Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: step 5, image 2 of 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Analog Battery Replacement: step 6, image 1 of 3 Quiksilver The Fifty50 Analog Battery Replacement: step 6, image 2 of 3 Quiksilver The Fifty50 Analog Battery Replacement: step 6, image 3 of 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Analog Battery Replacement: step 7, image 1 of 3 Quiksilver The Fifty50 Analog Battery Replacement: step 7, image 2 of 3 Quiksilver The Fifty50 Analog Battery Replacement: step 7, image 3 of 3
    • Remove the large circular Analog battery.
Sue Giske
622 Reputation
5 Guides authored
UW Tacoma, Team S1-G4, Liner Summer 2019 Member of UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 688
