Quiksilver The Fifty50 Back Panel Replacement
  1. Quiksilver The Fifty50 Back Panel Replacement, Strap: step 1, image 1 of 2 Quiksilver The Fifty50 Back Panel Replacement, Strap: step 1, image 2 of 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Back Panel Replacement: step 2, image 1 of 2 Quiksilver The Fifty50 Back Panel Replacement: step 2, image 2 of 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: step 3, image 1 of 2 Quiksilver The Fifty50 Back Panel Replacement, Back Panel: step 3, image 2 of 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Back Panel Replacement: step 4, image 1 of 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
Sue Giske
622 Reputation
5 Guides authored
UW Tacoma, Team S1-G4, Liner Summer 2019 Member of UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 220
