Logitech Performance MX Left Click Repair
  1. Logitech Performance MX Left Click Repair, Turn off the mouse and remove the battery: step 1, image 1 of 1
    • On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
  2. Logitech Performance MX Left Click Repair, Remove the 3 pads: step 2, image 1 of 1
    • To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
  3. Logitech Performance MX Left Click Repair, Remove the 4 screws: step 3, image 1 of 1
    • Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
  4. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: step 4, image 1 of 3 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: step 4, image 2 of 3 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: step 4, image 3 of 3
    • Slide the bottom to the side while removing the top
  5. Logitech Performance MX Left Click Repair, (optional) remove the connector: step 5, image 1 of 1
    • This step isn't necessary, but it makes it easier to work on the mouse.
  6. Logitech Performance MX Left Click Repair, (optional) put a bit of tape on top of the microswitch: step 6, image 1 of 1
    • This helps to avoid losing the white piece.
  7. Logitech Performance MX Left Click Repair, Remove the multiswitch top: step 7, image 1 of 2 Logitech Performance MX Left Click Repair, Remove the multiswitch top: step 7, image 2 of 2
    • Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
  8. Logitech Performance MX Left Click Repair, Flatten the metallic piece: step 8, image 1 of 2 Logitech Performance MX Left Click Repair, Flatten the metallic piece: step 8, image 2 of 2
    • Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
To reassemble the mouse, follow the instructions in the reverse order.
9 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Samuel Colin
630 Reputation
2 Guides authored
7 Comments
merci , ca vient de sauver ma Revolution
Clement Renaut - Reply
Avec plaisir. J'en suis ravi :)
Samuel Colin - Reply
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - Reply
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - Reply
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
Past 24 Hours: 17
Past 7 Days: 96
Past 30 Days: 402
All Time: 19,354
